IMHO, I find the length of the rod is immaterial, the actual dimension is meaningless. What you need is to have the brake lever at 15 degrees forward when the the brakes are ready to engage. As Pilotdave said, he used the shorter pin, and then had to install a pill to compensate for wear of the other parts. Its 6 of one, a half dozen of the other scenario. I would prefer not to use a pill, but sometimes they are necessary.
