Brake Pedal
jack wingard
The brake pedal doesn't come back even with the clutch pedal even with all the rods disconnected. It isn't this way in my sport coupe. This is a 29 Fordor. what am I missing or cant see.
I can't return it even with the clutch pedal, even by pulling back by hand with all the rods disconnected
1. most of the time it is the clutch pedal which is too far back.
2. Most common cause is that this clutch collar is worn.
Click to see photo:
https://modelastore.com/index.php?route=product/product&product_id=3714
+Do not weld clutch pedal until you replace this collar.
3. Collar usually is softer steel than pedals so collar wears first.
NOTE depending on how much collar is worn ... you might have to readjust clutch free play.
On my coupe both pedals arms are almost up against the floorboard on the underside, and just checked on another an it's the same way
I think Benson gave you the answer. It’s in the wear of the collar, most likely the clutch is to high. The collars are what control how far up the pedals travel.
1. If both pedals are the same distance from the floor board.
Then it is possible that someone bent the pedals for some reason.
