JRHASZARD
I am restoring a 1930 Tudor with Burt’s engine and 1939 transmission. I am not a real mechanic. I am having trouble installing the brake pedal return spring because of interference caused by the adapter that holds the pedal shaft . Does anyone have any hints or insights?
Also I am unsure what spark plugs to use on the Burt’s engine. I was advised Autolite 3095 but they are very tight. And without gaskets.Any comments.
