The general consensus is Moulded are better with cast-iron drums however the lining must be the softer lining and not the hard type that was made for hydraulic applications.
Some cast drums are suitable for woven linings, some are not. Check with your supplier. The brass woven through the woven linings scours the cast iron if the wrong grade of iron has been used.
