Dennis Pereira
This is only my own personal observation. I bought what I thought was the better of what is available with the hardened tools? The hardness is questionable. The tool That roles the rivet is starting to mushroom on both ends a little. After only doing the fronts I'm hoping it will last threw the job. also had to grind the front of the anvil so that when riveting the front and back where the shoe is thicker where roller pins go threw the tool was at a slight angle. So I messed up a couple of rivets. After grinding it worked great. I hope this did not turn into a rant. The tool works great It made knocking the old rivets out a breeze but quality seems to be lacking.
