I assume you are planning to double flare the ends of the line, single flares will not do the job. I have an old Blue Point double flaring kit and it does a decent job of forming double flares. The tool’s inserts are also gages for how far the tube should protrude from the clamping fixture
The first important rule is to put the nut on the tube, pointing the right direction, before forming the flare. The next important step is cut the tube off square and put an even 45 degree chamfer on the outside of the tube, this will ensure an evenly formed flare. Practice making some flares on scrap pieces before attempting the flare on your project.
Or take it to a hydraulic shop and have them form the flares, they have much better tools that I have. I did that when I needed a bubble flare for a late model Bonneville.
