Brake line clips
Does anyone have pictures or available sources for the brake line mounting clips that would have held the brake lines going to the front along the frame and crossmember and down the radius rods to the rear.I'm not looking for a particular year(maybe there all the same) as long as they are early ford
Thanks
Bill
Here's a few on a 40 Ford. I am sure someone will know of a source. I will remove one of the clips and take photos of it with dimensions so you can make some, if you so desire.
Just send me a PM.
I bought some stainless ones from Speedway, they work great, and I guess if you wanted them to look stock you could just paint them
Thanks for the pics and the info.I found some at McMaster Carr which should work just fine.Me and Speedway Motors don't get along to well anymore:(
Thanks again
Bill
Thanks again
Bill
What you need Bill is a beautifull flathead with Edelbrock Block Ietter heads and a Eddie Meyer intake with the tall runners. to go with those pipe clips. Walt
Thanks
Bill
I am sure Roy Nacewicz has them.
