Brake Lights
lameyer
Can you adjust the brake light sending unit (or whatever its called). It seems like it takes a lot of pedal pressure to get the brake lights to come on.
Some here have noted that mechanically operated switches, which are usually adjustable, can be more accurate/prompt.
However (1) be sure all electrical connections are clean and tight; (2) might be a good time to flush and replace the hydraulic fluid in the system and while doing that, remove, inspect and clean the existing switch, and if that doesn't improve its operation, replace the switch.
