The "A" Team
Hi, I'm in the process of hooking up the brake lights to my 1930 Model A Coupe, and running into a problem. I purchased a brand new wire harness, brake switch, pigtails and bulbs because the old ones were all rusted and frayed. I installed the new brake switch today, and then tried hitting the brakes after hooking the battery up. Nothing happened. I checked the bulbs and wires by touching them directly to the battery and the brake light lit up. I then checked the wire harness box at the bottom of the steering column and everything seems to be looking good. The headlights, high beams and parking lights light up no problem and the horn sounds when pressed. I also noticed that one time when I put the harness box on incorrectly, the brake lights did light up, but the headlight switch wasn't lined up correctly and I couldn't push the headlight switch as it was stuck. So I don't know what could be wrong that the brakes do not want to light up. Could the wire harness box at the bottom of the steering column be messed up? The wire harness box is the only item I didn't buy new.
Thanks.
Thanks.
