Freoway
I've got a '36 Ford roadster (factory RHD) that has a '39-42 juice brakes. This is the first car I've had with this setup. I've changed the front hoses, replaced the master cylinder (which is a later tandem PBR unit). Although the brake pedal is hard, the stopping power is lousy. The shoes have plenty of meat on them and the pedal isn't spongy. I've bled the system through.
I've noticed that all four have the adjusters on them and they work fine, but only the rear brakes have the lower anchor pins that are also adjustable. Should the front brakes have adjustable anchor pins, because they don't?
Cheers.
Cheers.
