Any 1940-48 drum will work for you. They may not have the same outside shape, but will directly interchange. You should have a tin gizmo to capture any grease slung off the wheel brgs. and keep it off the linings, not important unless there is a leak. Early drums like these are still safe with as much as .125" over-sized. If you are running wire wheels, you also need a wheel adapter as hyd. drums have a flat surface for the wheels to mount against, Ford wire wheels have a step in them. Good luck!
