Squeeze the brake fluid container so the fluid comes up to the top before putting the cap on, this way there is no moist air in the container. I have used silicon in my old Fords for over 30 years with no problems. You need new hoses and do not use NOS cylinders or cups. The old rubber had a dull finish and only lasts a week or so. The new rubber has a shine to it. I clean all the joints where the metal touches the plastic on the outsde of the switch, sand these areas a little and put a little bead of JB Weld to seal these areas. I have had no switch problems and have good a good solid pedal but they must be blead good and don't pump the pedal when bleeding. G.M.
