Brake drums
RB35
I have a set of '40 rear drums that are a bit out of spec and a set of '46 front drums that are OK. Can the '46 drums go on the'40 rear hubs. Internal vs external hub. Since the '46 hubs have a larger diameter hole, will the drums be hard to line up properly?
Thanks in advance.
RB35
RB35,
If you want NEW brake drums and ++ Asbestos ++ Brake Shoes, Give me a ring --
Craig -- 516 - 485 - 1935....
I have the inboard and outboard Mounted Brake Drums &
Both ++ Asbestos ++ brake shoes, the 1939 - 1941. & the 1942 - 1948....
Always best to simply call me . Craig. 516 - 485 - 1935....
if the bearing surface on your rear hubs are good, i would certainly buy new drums to fix them instead of trying to fit used parts. do you know how to remove the studs?
