When I see that ".060" is mentioned as the legal limit I was curious, in looking at the wording in state laws I find that an actual size is not mentioned, just "manufactures" specifications"
---an example of brake drum "law"-
6. Brake drums or disc brake rotors must not be contaminated in such a manner as to change the frictional qualities of the friction face or show mechanical damage to the friction surface other than wear.
7. Brake drums must be free of any external cracks, except when the drum is properly banded to prevent the crack from expanding to any degree upon the application of brakes or otherwise. Any bands so used must be free of cracks.
8. Brake drums or disc brake rotors must be free of any substantial cracks that reach an edge of the bore of the drum or periphery of the rotor.
9. The diameter of the brake drum at any point must not exceed the manufacturer’s allowable maximum, discard, diameter.
It is sometimes hard to find the spec, .060 is a common american spec for 50s, 60s, 70s brake drums, but some are .080, some .030, and I have also seen .187 as a spec on a drum---I think 1971 is the first year the drum itself had to be marked with the max size
For the model A --on page 514 of the service bulletins it says---
"Under NO circumstances must any attempts be made to turn down brake drums on A cars and AA trucks."
Therefore if the manufacturers specifications are used it can be reasoned that ANY turned A drum is not legal ---
When I was looking for drums I made a gauge out of brazing rod --2 piece 1-6",1- 5.020, another 6.020 --I was looking for some 12" drums for a 36 also.
i figured that I didn't want any drums over .030 if I am to have "good as new" brakes, the .040 drums went out of round quick on the front. ---
