Brake Drum ID
Gary/IA
I just removed this drum from my '29 Tudor. Upon inspection it appears the ring on the drum was made on it and not installed later.
Was this a common replacement drum back in the day or have I found a unique treasure? :confused:
Mike V.: put your cursor on the phhoto, hold down Ctrl and hit the + key, makes e/thing larger, to restore hit the - key
Paul in CT
Looks like the late '31 cast. I have three cars with the fronts but have never seen a rear. You're fortunate. Can be turned out as much as .060.
