1946 Super Deluxe
I need some help figuring out how to attach the retractor springs. The car didn’t have a brake spring when I bought it, so nothing to go on there. The clutch spring was in place and I have replaced it as I found it, but it doesn’t retract the clutch arm when I push it down - if I pull it back over the hump it will finish the job, but I don’t think that’s the way it should work!
I purchased new springs (99A-7523; 7.6” per the Green Book). The 7.6” spring on the clutch is just a bit too long to do anything. And I can’t even find any place to hook a 7.6” spring on the brake side. So, I don’t know if the springs are not correct or if I’m really missing something else.
I’m attaching a few pictures and would appreciate any advise.
Thanks.
Thanks.
