Brake/clutch pedal assembly rebuild
37fordpickup
I am trying to rebuild the brake/clutch pedal assembly for my 37 1/2 ton pick up. I have it all apart and I have found all of the replacement parts except the pins that are pressed thru the shaft pin at each end. When I took it apart I had to drive the old ones out with a drift pin. Does anyone know what the part number and source might be?
jsnyder223@comcast.net
