On my 26 model t the front drum brake line goes through the frame. The hole it goes thru is to large for the hydraulic line. The hose I bought has a c clip used for to keep the line from moving. I was going to use the c clip to prevent the hose from going into the frame. Does anyone about this c clip that comes on new hydraulic hoses? If I can’t find a c clip do you think a e clip would work? I just need the c clip or e clip to take up slack to prevent the brake hose from going into the frame
Thank
Jerry
Thank
Jerry
