My A came with hydraulic brakes. I believe I have a vacuum leak, car idles fast, motor wants to die if you give it gas or apply any load after starting it. Once you've driven a few miles then it seem mostly fine.
I pulled the vaccum line off the power booster and plugged it, the motor seemed to idle better so I'm guessing the power booster is leaking internally. Anyone able to ID the booster and master cylinder in this pic?
Thanks
Thanks
