I ran hydraulic brakes on an A coupe like a '39-'48, but I'm having a hard time getting the banjo bolt T to seal. With pressure on the system I get a very faint seeping around the bolt head side of the washer. And yes, I annealed the copper washers and tightened the bolt as much as it would go. I read on here that the original style crush washers had rings like the brass junction, is that true? Some of concentric rings on the reproduction brass junction seem to be of poor quality. I assume they should be void of nicks and deformed edges to get a proper seal. The bolt was an NOS Ford unit with the correct recessed taper.
Has anyone else had this issue? Any ideas?
