Brake backing plate
jack wingard
Brake ? Starting to re-assemble brake backing plate to spindle. Diagram shows castle nut on the rear of plate. When I removed it originally the castle nut was inside the grease baffle. I like that the threads were protected that way. Does it really make a difference?
Jack, many hobbyists have incorrectly installed the front fasteners on the Brake Housing plates. The nuts were located on the outside originally, however many people have successfully driven for years with the nuts mounted onto the inside.
Often times on early 28's, the front backing plates were mounted with the heads facing out and nuts in. There were spacers on the early '28 grease baffles which made this possible.
