I did some calculations on the shoe movement at the wedge end ,verses the clevis moment the shoes move 3 -1/16 to one inch of clevis arm moment the front is the same as the back ,The rashio front to back is determined by the equalizer bar or cross shafts clevis arm length or the ratio between the two .On the rear brakes its 100 mm long on the clevis arm on the bar its 70 mm this is a reduction ,On the front its 65mm on the bar and 60 mm on the front clevis ,Because on the bar its longer this brings the front on first ,I agree with Steve you can change the bias front to back ,The 37 Ford relied a lot on the springs to give the self energizing affect. The photo on the right is a self energizer on a 34 Chev (not joined at the heal ) there were many forms of self energizers around in the 30s ,as far as I can tell Ford didn't use them because he did not want to pay royalty's,
