What is the reasoned opinion of others?
This string is the 1st I've seen that says to adjust so front brakes lock up before back. Am confused - wouldn't this method be dangerous in gravel/dirt/pea gravel?
In the day unless you lived in town/city most driving was not on paved roads.
People can make whatever mods that they like and I have no problem . My mention of longer brake levers was that model A's have longer rear brake levers . The leverage of the longer levers cause the rear brakes to activate quicker and should have more power . The rear brake bias is built in because of the longer brake levers .
The upside of having the rear brakes lock first in gravel is that you will be able to steer. The downsides are that it will take a lot longer to stop and the rear of the car will likely pass you during the attempted stop.
How often will we experience a panic stop in gravel vs on pavement?
All cars since the mid 1930's have the braking proportioned so that the fronts do 75% of the braking and will lock first in a panic stop. Was Henry right with the Model A and everyone since wrong? Was Henry right with the 2 wheel brakes on the Model T?
I also use the floating lower pin in the front lower brake wedges . This setup helps center the lower front brake shoes .
