After restoring all four brakes with new shoes, same length rods, etc. I can't get rid of the drag in the right rear. I suspect it is the adjusting wedge. To get the brake to lock up according to the method in
Andrews book, I have to tighten the wedge all the way but at that point it suddenly goes loose and I can't get it to hold unless I back it off one or two notches . Does this suggest the threads are stripped? Apparently I never checked it. Can the wedge be replaced without totally dismantling the brake? I also didn't center the shoes as the tool is expensive. Thanks for any help.
