Hello We are new owners of a late 31 coupe. We got to drive it about 350 miles this past fall, sometimes around the neighborhood with more children in the rumble seat than approved.
When we got the car it was running on an auxiliary gas tank which was removed and cleaning the original tank commenced with longer and longer rides around the block which circuitously is about one mile. It now can be driven with confidence as long as a new filter and the assorted items are along for a quick but safe roadside change. The exhaust manifold must be respected.
The brakes worked well enough that I was never scared by their response to any situation that occurred during the 350 miles but I did notice that they would kind of hang just a bit when pulling out.
Just about time the weather was going to be the deciding factor to putting the car away for the winter I noticed a broken anti-rattle spring on the right front, replacing the spring revealed that the brake operating arm went from 15 degrees front to 5 degrees front before doing anything and was the wrong way before the brake was locked.
Taking the drum off everything looks like new but greased 40 years ago when the car was (I was told) restored. Other than relubricating everything and adding a pill to the operating wedge no parts need replacing but now I need to install the new dust shields and am wondering if there are any tricks as it appears that the edge of the adjuster housing where the dust cap sits may have been peened over a bit.
So after all that can anyone suggest how to install adjusting wedge dust caps.
Thank you,
Jay
Thank you,
Jay
