Brackets to support split brake shafts to frame
wrndln
Lakeville
MN
I need the 4 brackets that fasten the outer ends to the frame for the early 28 split brake shafts. These bracket are similar to the later style, but are not the same. The opening in the center is smaller than the later style, as there is no bushing in the early brake system. The picture below shows the outer brackets.
Rusty Nelson
