Bracket on firewall
Klattu1929
What is this bracket on the firewall just above the steering column cutout, don't know if I need it or should remove it and fill the hole. Also, my car is titled as a '29 but the date stamped on the firewall just above the seam for the gas tank is 6/18/28, engine serial #makes that as April of '29, so I may have a mixture of different cars.
Current build on my chassis, ran the engine, sounds pretty good, drove down my driveway sitting on the home depot bucket, had to use a light switch for my ignition as I don't have a proper switch yet. going to install shields on each side of oil pan next. Good times.
by the pix, your car looking good! clean work!! always a good sign when one can improvise in a component and get the system to work as if running all the right parts! :)
Being from Washington, wondering where you might be located? i can remember way back and there was no I5 there in Seattle, only the 99! ~
I've not really found anything definitive on this bracket/feedthrough. Will leave it for now, can always weld up the hole if need be. Drive on. thanx.
Some Model T's had a brass plated "Ford" in raised letters on a oil can. Quite handy to have but cheapo Henry Xed it
It doesn't look like any kind of oil can holder I've ever seen and definitely not original Model A. What's on the back side of it - i.e. what are the 4 tabs holding in place? Resembles the remains of something electrical to me. Don't loose any sleep over removing it and welding up the holes!!
You've checked the engine number and firewall date, have you checked for a number stamped on the frame? Do you have a title and if so does it match anything else?
Frame s/n is long gone to corrosion, that was a disappointment. I have been wondering if it is a feedthrough fitting for vacuum wiper line, but after looking at the S/B the vacumm line routes near the fuel line passenger side. Long story short, I'll leave it, add it to another "A" mystery. If it bothers me enough I'll weld it up. Thanx for the inputs and ideas, wish my car could talk!!
Possibly a "part" of an old battery box assembly? Or, perhaps part of an old "Up-starter".
There were many companies that sold the parts to move the battery up under the hood on Model A's & other cars.
