Mike/Franklin
I'm helping out some friends finishing assembly of a 32 Ford pickup. Owner/fabricator recently passed away and left about 80% assembled including a GM 3 speed with the Borg Warner already attached and drive shaft fit to the rear.
Question, can the overdrive be set as a pass through 1to 1 ratio?. And not use the overdrive feature. Nobody knows much about these units. They don't want to take it out of the driveline equation and have to redo mounts and driveshaft. Enough challenges already.
Thanks ML
Thanks ML
