Britcheflee
Hello, I am a new member and whilst searching for help via google realized that there are a lot of very knowledgeable people here who may be able to help with an issue I have with my overdrive.
I have a 1953 Mercury with the BW overdrive which has been mentioned in previous posts I have the same issue as Fred in France had: I have re-wired everything and confirmed all works - however, since re-wiring and activating the solenoid both by grounding TH post on relay and by direct power to post on solenoid (both working) I cannot get it to ground and briefly stop the motor either stationary or whilst driving. The switch is new and I have confirmed that I get continuity across the two posts when it is pressed in - I have also used a wire to ground the wire from the coil on the switch posts and it briefly stops the motor. So, somehow what is supposed to ground in that solenoid is not grounding. Not sure what to do now. I would like to take that solenoid off the transmission whilst it is up on blocks but concerned about how difficult it is to re-install - does it just pop right back in?
Also at the back bottom of the separate section of the transmission where the OD system is I see a small thing which can only be described as a rubber bung - is this the drain hole for the OD section? I have posted a pic pointing at that bung/drain hole thing.
Finally, am I fussing over nothing - just how noticable is the overdrive when it is engaged/disengaged? I dont feel any change in power, rpm or anything when driving along but it might be so slight not to be aware of it.
LOTs of questions sorry hopefully some info from you guys can help me out.
Lee
Lee
