bolt toeque specs
sach
Looking to find the bolt torque specs, for the body to frame, mounting bolts.
'28 '31, 4 door sedan.
Thanks, Sach.
Ford issued no torque specs for the Model A Ford. Those that are around today have been created by the hobby. Most of them employ the industry standard specs for the size and material of the bolt or screw.
Just tighten the body bolts. They will be fine.
It's not easy to know how much to tighten a nut. In the past, I would just tighten every nut as much as I could!
Many years later, I learned to use much less force, but it's still mainly something you just learn.
I would try to make them "snug" and not as tight as you can.
Marc
