RalphG
Well the heat gauge works on the Merc anyway. I didn't believe it was that hot. Checked the top hoses several times with my hand and they were not all that hot yet the gauge read nearly to the last dot. Ambient temp was around +20F at most so I had the rad covered to warm it up properly. Got a little bit stuck with the bald tires when I stopped to take a picture. In the process of rocking back and forth I lost sight of the guage and next thing steam came from under the hood. A stream of anti freeze was spraying from a weak spot in the tank over the engine, hitting the hood and soaking the coil wire to the dist. So now I know, trust the heat gauge.
