Randy in ca
That's an interesting photo that Jim posted above - appears to be a very early chassis - even looks to have the straight side rails on the frame?
I believe that photo is much earlier in the process. Here's one from after Marco's photo..still no sign of welting....
I have not studied this at all, but would it be possible that the 'frame' welting was actually pre-attached to the fender / running board prior to installation??
Just a thought!
To further Marco's point, the anti squeak webbing that I have has pre cut holes that are oblong in pattern to fit over the holes where required fasteners were located. OK, now if the bolts that hold the running board aprons are installed with threaded side up, bolts and washers on top, how did the wood sills fit over that...were there holes drilled to clear those fasteners?
Gary,
As I said in my post, there was no rear section until the aprons were changed in mid '28. My best guess is that when they transitioned to the later configuration they shortened the length of A-16540. And of course the "A" suffix wasn't used until the "B" version was introduced for the 1930 models.
The one thing that still confuses me is just why they chose to segment the anti-squeak at all. I've not yet found the logic in it.
It had to have been cost since much of the anti-squeak is sitting there on the top frame rail doing nothing, but I wonder if they glued it on during assembly to keep it on.
16540
16541
16542
16543
16540-A is for 28-29 front fenders. 16540-B is longer as it extends to the front tip of the fender @ the apron. 16541 was introduced with the new running board aprons in mid '28. I think that answers all the questions that would have arose when looking them up.
