56sedandelivery
The pest is back.
So getting ready to hang fenders as in previous thread. Figured I would try and replace the body to frame mount that is in the engine bay area. Got the top nut off no problem and now am stuck. It looks like the mounting bolt is just a bolt threaded the whole way with no nut attached. The top bolt came off easy but the bottom will not budge. I do not know if the bottom nut or whatever it is, is welded to the frame or not. I tried the jam nut on the top and bolt nuts just unscrewed. I put WD40 on it and will let it set overnight and see what happens. Any idea other then that to get it out? Thanks
