Daves55Sedan
If the bolts were all in a straight line down the side-rail it might be okay, but since that is not the case, I would fear bending floor metal by raising only one side of the car. I suggest at least loosening up all the opposite side bolts leaving at least 1/4" of the bolt sticking up above the floor. Don't forget about the very front and back bolts too. Those will be the most restrictive to allowing the opposite side to lift since they are not in the same plane as most of the other bolts.Dragging up a old thread of mine. Next question can you do one at a time or do you need to loosen the entire side. I am hoping I can take one out, jack up that are enough to slide the new one in. Is there enough give to do it that way? Do not want to tweak anything doing this.
