body mounts
4ford
hello anyone have information on body mounts on a 1941 coupe? how many ? and where there placed?
thanks for your help
mike
Mike,
Dennis Carpenter has a mount kit in stock that comes with instructions that would show the placement. Their is a picture of the assortment of pads.
See if this works, it says 42 to 48 but the basic body should be the same on 41.
I had a time finding rubber mounts for my '41 fordor. should be the same as a tudor & possibly a coupe. anyway when I got them basically none really matched what I had on the car. Had to juggle them around to get the right combo of style, thickness etc.
Had the same problem with my 39 tudor. Kit was about 90% accurate.If you change your mounts consider buying the bolt kit as many will not come out easy. Mark
I bought the bolt kit too, but many were not the right length/amount needed,
Had to”juggle around” as Fordor41 did with mounts, and still ended up going to the hardware store for a few. Bolts that is.
I bought the book.. I gave it to my friend who has a 41 fordor..
Although it has some cool info.. it was not as detailed as I hoped it would be..
Now I must ask, should I replace all the body mount pads on my 47? Do they make them in Urethane? :eek:
my doors fit fine before changing the body mounts and after they are low by 1/2 inch. this is on a 39 tudor. waiting to get the engine back in before trying to correct. Mark
