D Dune Country Member Jun 7, 2012 #1 Do you paint,oil,varnish or treat your body blocks when assembling a model A?
PetesPonies Senior Member Jun 7, 2012 #2 I redid an early Jeep which used wood inside the mounting channels. I ended up using Trex, cut down to size. I was wondering if anyone used a similar synthetic wood for blocking rather than real wood?
Aerocraft Well-known member Jun 7, 2012 #3 I varnish them and then spray several coats of PPG DP-90 epoxy (satin black). Gar Williams
