Bob Drake Gas Tank
Great thanks everyone. started another thread on the bed build with question of course. If you guys have time check it out and comment.
Here's a photo depicting the tank inlet on my restoration.
Be sure you check the romoveability of your tank before installing the bed. The neck on my Drake tank was mislocated as mentioned here and was slightly miscontoured which
unfortunately will not allow it to be removed from the from the frame in the normal way.
I installed the tank prior to installing the bed.
Charlie ny
Even on the original tanks you have to Force the tank to the left so
the tank flange clears the right side bottom frame rail. G.M.
