blue on the pipes
rollingsculpture
taken from a quote from desotoguy
I suppose that if you have 15 grand to put into a Model A engine you don't care if it never seemed to run exactly right. The blue on the pipes may be a clue.
hmm as far as i remember from trying to purposely get those colors solid accross a thin sheet of metal using a kiln the coloration achieved magenta coming up first around 490 and the blues 550 degrees or so
my question is what should be expected to be the normal exhaust temprature
Happens a lot on motor cycle pipes that are not double walled.Also an indication if a slightly lean mixture in carb. OMO. ken ct.
