Need some help! Both of My High Beams blew at the same time. Driving home, I turned on the high beams - they got real bright for a second, then went Black. Turned back to low beam, they were and are fine.
I'm running a 6 Volt Alternator, New Harness, Bulbs are grounded ( 0.3 ohms back to battery). Do not see any nicks in the insulation. Connections are tight.
Alternator housing, also has 0.3 ohms to battery. I'm at a loss ! Any ideas out there?
Thanks; Tom in Atlanta
