I just acquired a stock '30 Sedan that had a mild restoration done sometime in the 80's. It runs but its a really rough idle and backfires real bad, even after adjusting the distributor timing, points, and GAV. It does have a pretty bad exhaust leak on the exhaust manifold at cylinder #1 and starting on cylinder #2. I didn't think of this at the time, but is it safe to say if the exaust is leaking then the intake on #1 is also leaking and causing a bad air-fuel ratio? Would it be wise to spray starting fluid on the intake and see if the idle note changes?
