1931flathead
what you guys think about a 471 bower on a 4 bbl intake for the old school look
my boss has a 671 on a chevy sbc but they have plates weld to the intake to hold it down been on there for years
I guess you have looked at this.
http://www.fordbarn.com/forum/showthread.php?t=197279&highlight=blower+intake
I used a one inch plate with a fifth hole in the middle and have a pop off valve on the side of the manifold and I needed it on first drive due to magneto and carb problems. I run a max of 4 psi of boost with two 5/8 belts. Be sure and use the old style manifold where the carb mount surface is parallel to crank. The plate sits on top of the front of the manifold with a couple of gasket pieces as a shim. To date it has survived about 500 miles.
