Rex_A_Lott
To answer your question, yes it can be welded, several different ways. It can be stick welded with a nickel rod. It can be gas welded with a cast iron rod. There is a process using a special torch using a cast iron powder introduced into the flame.( I've never done this one but I've seen it demonstrated). It can be brazed ( yes I know this is technically not welding).
There is also the stitch method, as mentioned, to do crack repair. Uses tapered pins that overlap each other.
JB weld has also worked for many.
We all think that the old ways are better, (and they are for some things), that's why we are attracted to this hobby. But , sometimes, as my old Vo-tech welding instructor used to say, " There's more ways to choke a dog than feeding him butter". Sometimes I wonder just how much one of the old farmers would have given for a couple of tubes of JB Weld.
The good news, many fixes available. The bad news, you have to make up your own mind, you'll never get agreement out of this bunch.
Good Luck.
