Lots of opinions on that question. Each has advantages. The primary B advantage is pressure oil to the mains which may be preferable if you are going with inserts and annular grooves in the mains. (Another point of controversy.) The A has thicker casting on the top, some (me included) say it is less suseptible to cracking.
But as with any modification, it depends on the intended use. Modifications should be part of an overall system, each modification complimenting the other. You dont say what "upgrades" you intend for the valve train/cam, how high the compression, carburation, flywheel, etc. With all due respect, it sounds like you are just plugging in ideas you have heard without considering the overall picture. For general touring I don't think it would make much difference which you used. My incination would be to stay with the stock A block in your car unless you are going to get radical. Then everything is on the table and is a whole different discussion.
