Anyone drilled and tapped the later 8BA type blocks for a block drain. The 59L has one right where it should be, at front low point. The 8RT has none.
I assume you could probably drill out the 8BA at the same point for a drain.
Or will the drain hole in the water pump get most of the water out of an 8RT. ? Thank you Fordbarners.
