Blinkers
Steve Ferguson
Where do you start trouble shooting a problem with blinkers when you have LED lights? When i put on the flashers, they all work. Rear brake lights work. But when I use the blinkers, only the left front blinker works.
Signal lights require a special flasher for LED's because the draw from LEDs is not enough to make a standard flasher work
I have a 12 volt system in my '36 with LED bulbs. I use the Novita EP34 flasher, from Advanced Auto. There is probably something similar for 6 volt.
