6lucky13
I was having problems with an engine miss and stumble that is noticeable at idle and very pronounced on acceleration in 1st or 2nd gear. This is a 37 engine in a 36 Cabriolet. I’m using a 37-41 distributor with an FA49 condenser. I recently installed a rebuilt coil, new condenser, and new terminal caps. I also replaced the under dash ignition resistor. Still misses and hesitates.
Pondering my next steps, I recently checked the oil and the dipstick was BLACK! The oil has only 142 miles after a recent change. I removed all plugs and they too were sooty black.
What are the possible causes for the black oil and fouled plugs? I’m guessing a carb issue with a massive leak causing over rich condition but the carb was recently rebuilt and has <300 miles run-time. Am I correct about a carb issue or are there other causes which would give the conditions I described? What are my next steps?
I need help…thanks…
I need help…thanks…
