trainguy
Just finished installing and dialing in a large bore carb on my 46 Merc.The engine is a 59 block with Ross 35/16 pistons and a Scat 41/8 stroker crank.It has a Isky Max 1 cam.I built the engine more for torque than for HP because the heavy merc convert is equipped with a Columbia 2 speed rear.When I built it I installed a stock holly 94 carb,and it ran reasonably well. At Hershey I talked to Charlie NY and he indicated that he could build me a large bore stock appearing carb that my existing air cleaner would fit,but I would have to bore my intake bores out to 11/16 dia. to match the carb.I had to sleave the bores after I broke in to the exaust heat riser.Initally I had to apply the choke a bit to make the engine run properly.After discussing the problem Charlie sent me larger jets to richen the mixture.That solved the problem.The new carb made a big improvement in performance.I don,t know the application for the carb,maybe Charlie will answer that question.I just want to thank Charlie for the fantastic work! Phil
