Check the "Fit" of the rotor to the shaft. Some wobble around. I tighten them with a paper insert.
I got the '42 crab style cap and rotor from NAPA but I can see it wouldn't work for me, even in a pinch, without boots to seal around where the wires plug into the cap. NAPA doesn't carry those and neither does C&G nor Mac's. So, where do I get them?
Brillman...https://www.brillman.com/
They have every known flavor of wire, terminal, and boot.
Traditional aftermarket recipe would be Packard 440 and Rajah terminals...
I will put some in your "care" package...
What Tim said.![]()
Jim:
Once again showing how much of an asset you are to this hobby.
You're the best.
Tim
Just a note with the NAPA FA64 and FA65 cap . The rotor needs just a little bit filed off the tip when new as it sometimes hits the cap terminals. I think these are the very best crab cap you can get and have used hundreds of them . However they often hit the contacts....
On the rabbitt ear cap i think we just have a quality issue with the center button. I looked at what was laying around here today ( orginal old stuff) and most seemed to have a much better center button contact.
I hardly ever use this style cap and would be glad to make a ole Henry donation of a couple really nice used caps (orginal ford etc). Pm if ya want them and i will get them to you..
