bill3337
I'm about ready to install the glass in my '37 Ford two piece windshield frame.
I considered setting it completely in urethane, but worried that if I ever have to replace the glass, I may not be able to get it out without destroying the frame. I could use bedding tape, but to install the glass, it has to go against the center bar, bottom frame and side frame all at the same time. How would you get it to go in with tape on 3 sides? I thought if I did use the bedding tape, I might cut it down on a 45 at the frame and then caulk the surface with urethane to keep it watertight. Anyone have suggestions how to do this? Thanks, Bill
