It all depends how you want the stance. If you are keeping the frame stock, you're going to have to mount the spring on top of the bells. This can be accomplished with a spring hanger kit from Speedway, or by cutting the hangers and bolthole area off Model A bells. The A spring can stand to have a few leaves removed, which will make it ride better and lower it a little. If you want it to sit a few inches lower, a T spring will do it, but will require a spacer to be made because it's narrower than the A spring.
